NEED IDEAS
Go to solution Solved by ShadowUsher_26,
Budget (including currency): 5000$
Country: us
Games, programs or workloads that it will be used for: Adobe Premiere Pro
Headphones
  1. 1. Which one is better? I am really having a lot of problem choosing.
    • Razer Nari
    • Razer Kraken Ultimatre
    • Hyperx Cloud Alpha
    • Hyperx Cloud II
Country: us
https://linustechtips.com/topic/1277479-need-ideas/
16 minutes ago, fpo said:
Sennheiser studio headphones.
Well i dont want to spend extra on a mic so just something with a nice mic which can slide in like the Razer Nari.
  • Over ear
  • 7.1 Dolby surround sound (you know all that cool shit )
  • Nice mic
  • 100$-150$
https://linustechtips.com/topic/1277479-need-ideas/#findComment-14274901
52 minutes ago, Battleaxe_26 said:
Really like the idea man Thanks
NP.
the general consensus of audiophiles is that gamer headphones suck n
1 in quality
2 in equalization. They prefer bass over all the sound.
Studio headphones will have you hear everything correctly.
The blue snowball is also an easy usb mic that yeah has to sit on your desk but it's a million times better than integrated mics and from what I've observed, just as good as blue yetis and hardly a difference between xlr for YouTube's compression.
https://linustechtips.com/topic/1277479-need-ideas/#findComment-14275045
Country: us
do NOT, i repeat do NOT buy gaming headphones. just buy Beyerdynamic dt770's for 120 euros. it is what proffesional musicc producers use including me.
if a gaming headset would have the quality of the dt770 it would be sold for 500 euros
https://linustechtips.com/topic/1277479-need-ideas/#findComment-14275104
