IDE Cable
Go to solution Solved by WhitetailAni,
You will need a cable.
They are built to specific tolerances.
And yes, you will need all of them except the missing pin.
I have much experience with IDE.
Hi, I need to use my old IDE drive tomorrow, but I can't find a cable for it.
So my question is: Is it necessary to connect all of the 40 pins on the drive and motherboard? Are some of them just optional? Or do I need to connect all of them?
PS.: I have no idea how IDE drives work so sorry for such a dumb question.
https://linustechtips.com/topic/1277062-ide-cable/
All 40 pins (or 39) are needed.
You should use an IDE cable. You can probably manage to use 40 jumper wires (pre-terminated) IF you can configure the ide port to something lower like PIO2 ... PIO4 from bios or something like that instead of UDMA33 or higher - though you need a 80 pin cable for UDMA66/100/133.
PIO2 .. PIO4 is slow and cpu intensive, the speeds will be somewhere around 10-20 megabytes/s
https://linustechtips.com/topic/1277062-ide-cable/#findComment-14272148
