This says o isn't an int therefore it cant be ordered. Do you know why?
i = 2
o = 0
chain = 0
number = 0
def collatz(x):
    if x % 2 == 0:
        return (x/2)
    else:
        return (x*3+1)
def sequences(x):
    a = 1
    x = collatz(x)
    a += 1
    if x == 1:
        return(a)
while(i<1000000):
    o = sequences(i)
    if o > chain:
        chain = o
        number = i
    i+=1
i = 2
o = 0
chain = 0
number = 0
def collatz(x):
    if x % 2 == 0:
        return (x/2)
    else:
        return (x*3+1)
def sequences(x):
    a = 1
    x = collatz(x)
    a += 1
    if x == 1:
        return(a)
while(i<1000000):
    o = sequences(i)
    if o > chain:
        chain = o
        number = i
    i+=1
https://linustechtips.com/topic/1276269-project-euler-14/
def sequences(x):
    a = 1
    x = collatz(x)
    a += 1
    if x == 1:
        return(a)
this doesn't return anything if x is not 1 so when you run
    o = sequences(i)
you only get an integer if collatz(i) is 1. Otherwise it's None which can't be compared with an integer..
sudo chmod -R 000 /*
https://linustechtips.com/topic/1276269-project-euler-14/#findComment-14266159
19 hours ago, Sauron said:
def sequences(x):
    a = 1
    x = collatz(x)
    a += 1
    if x == 1:
        return(a)
    o = sequences(i)
Thanks, I should have put a loop there.
https://linustechtips.com/topic/1276269-project-euler-14/#findComment-14268294
