I've been running 3DMark on my PC and am a bit confused with the results I am getting.  I've looked at so many websites and these are the numbers I've found:
  • Nvidia website states the RTX3090 boost clock is 1.70GHz
  • The Asus website doesn't seem to list clock speed
  • TechPowerUp lists 1860MHz (+10%)
  • Some review sites list 1890MHz
  • My 3D mark tests show clock speeds as high as 2050MHz
I haven't done any manually overclocking so I'm wondering if the Asus ROG STRIX 3090 OC just OC to whatever speed it can reach without crashing but I can't figure out what determines the Boost clock in my sample and if it's a good number.
Gaming Rig:
  • CPU: Intel Core i9 10900K
  • Motherboard: Asus Maximus XII Formula
  • RAM: Corsair White Dominator Platinum RGB 4x16GB DDR4-3200
  • GPU: Asus ROG STRIX 3090 OC
  • Case: Lian Li Dynamic XL White
  • Storage: 2x Samsung 2TB 970 EVO Plus NVME; 4x Western Digital 4TB Blue HDD
  • Asus ThunderboltEX 3-TR expansion card
  • PSU: Corsair HX1200i
  • Monitor: Alienware 34" 3440x1440
  • Cooling: NZXT Z73; 13x Corsair QL120
  • Lighting: 3x Corsair Commander Pro; 3x Corsair RGB LED Fan Hub
  • Keyboard: Logitech G910 Orion
  • Mouse: Logitech G Pro Wireless; Logitech G502 Lightspeed
  • Headset: Sennheiser Game One / Sennheiser HD800S
  • OS: Windows 10 Pro
Gaming Laptop:
  • 2020 Dell XPS 17"
  • CPU: Intel Core i7 8-core 10875H
  • RAM: 2x 16GB 2933MHz
  • GPU: NVidia RTX 2060 6GB GDDR6
  • Storage: 2TB SSD
Working Laptop:
  • 2019 MacBook Pro 16"
  • CPU: Intel Core i9 8-core 2.3GHz
  • RAM: 32GB 2666MHz
  • GPU: Radeon Pro 5500M
  • Storage: 2TB SSD
  • OS: MacOS
NAS:
  • QNAP TS-853 Pro
https://linustechtips.com/topic/1275704-how-does-boost-clock-work/
Whatever Nvidia lists on the site is the advertised speed for the founders edition. Board partners like Asus will almost always advertise a different (higher) speed because they're not selling a founders edition, they're selling a different product.
GPU boost is part of the Nvidia driver that automatically boosts clocks if you have the thermal and power headroom to spare. In the majority of cases, you will end up automatically getting clock speeds above what is advertised, but how much you get will vary. Not all chips are made equal, and there is variance in silicon quality.
Primary PC:
PSU tier list
How many watts do I need?
i would assume this is the minimum boost clock
though im not sure if it's guaranteed, since there's base clock for that
but actual cards will boost higher than that when headrooms are available
-sigh- feeling like I'm being too negative lately
Thanks.  I understand what silicon lottery is and how it affects manual overclocking but I didn't expect there to be auto overclocking.  I wonder what the difference is then between the Asus regular 3090 ROG STRIX and the OC version.  It sounds like they would both overclock automatically.
Gaming Rig:
Gaming Laptop:
  • 2020 Dell XPS 17"
  • Storage: 2TB SSD
Working Laptop:
  • RAM: 32GB 2666MHz
  • Storage: 2TB SSD
  • OS: MacOS
NAS:
  • QNAP TS-853 Pro
Just a small differencw in binning, and maybe a different power limit setting in the card's BIOS
Primary PC:
PSU tier list
Thanks.  I did some searching to see how Nvidia Boost works and the explanations all seemed like it's different for every card.  The Nvidia driver takes into account the power limit, temperature and voltage (I'm not an expert so I might have some things wrong) and then just adjusts the clock on the fly.   So if this is true, it means the that non-OC and OC variants of the Asus card could perform similarly since the boost frequency is determined more by the Nvidia driver.  i.e. a good 3080 non-OC might perform the same as a 3090 OC-variant.
Gaming Rig:
Gaming Laptop:
  • 2020 Dell XPS 17"
  • Storage: 2TB SSD
Working Laptop:
  • RAM: 32GB 2666MHz
  • Storage: 2TB SSD
  • OS: MacOS
NAS:
  • QNAP TS-853 Pro
Well you won't quite be getting that level of performance gap being closed unless the 3090 was under some pretty severe thermal restrictions but you definitely understand
the general idea.
Primary PC:
PSU tier list
