Not enough info at all...
Really depends on the needs, wants and duties you require to be fulfilled...
Its an ACE Desktop Office PC with an SSD.
But that 8600GPU wont play todays games (within reason due to DX11+ Games)
Max GPU I'd be using is a GTX970 or RX470/570 Class GPU for 1080p and even then it still depends what games and needs you want.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1275375-bottleneck-help/#findComment-14259054
the 8600GT is obsolete, the 3450 is not
the i5 is 5 years newer
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1275375-bottleneck-help/#findComment-14259064
