Hello. Got a problem. Yesterday changed thermall paste on chip and broke 3 chips from 3770k stock coller now i must work add weight  on in but it idles on 50c degrees and when using a bit of cpu goes to 80-95 must use it till tuesday wont my pc don't explode or burn ? Also tuned down the mutiplier on bios to lover settings
https://linustechtips.com/topic/1274166-about-cooling/
The maximum temperature in for your CPU is 105c before your CPU starts to thermal throttle which is bad.
max temp should be 80c but if you are running hotter than that you have a problem with your cooler
What do you mean when you "broke 3 chips from 3770k?"
Also what is you CPU clock rate at?
What cooler do you have?
https://linustechtips.com/topic/1274166-about-cooling/#findComment-14249980
when instaling it's old pc but work one and they was dark yellow when instaled fixed it and they snapped
so question is i need to work but it will survive till tuesday because can't change it now and have a lot of work. Mabey i should just a bit lower a volts or smth just not to get too hot
https://linustechtips.com/topic/1274166-about-cooling/#findComment-14249990
9 hours ago, DrakasLT said:
It would be enough with some undervolting and might be fine at stock.
The Ice Edge Mini FS may be a bit better and should handle stock settings: https://www.varle.lt/ausintuvai/deepcool-ice-edge-mini-fs-universal-cooler-2-heatpipes--5226298.html
Here's an example on the 3770k: https://youtu.be/jlI2nTq6-Ng?t=215
Please format text a little more cleanly. The question in your post is easy to miss since it looks like it's part of the url.
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/1274166-about-cooling/#findComment-14251721
  • 2 weeks later...
