I am going to be replacing my mobo, psu and gpu.
Right now I have-
i7-9700k
GTX 1060 3GB
A cyberpower motherboard made by ASRock (not a good mobo)
2x8GB RAM
600 Watt non certifiied (psu)
Be Quiet! Dark Rock TF
What I will be changing-
Swapping out 1060 to RTX 3070.
Swapping out motherboard to a MSI MPG Z390 Gaming Pro Carbon AC. (If you know a better mobo for around the same price point or cheaper let me know)
Swapping out PSU to a Corsair RM 750Watt 80+ Gold. (If you know a better PSU for around the sanme price point or cheaper let me know)
I want a PSU that was 80+ Gold certified or higher and I want it to be at least 700 Watt for some headroom for future upgrades and overclocking. Open to suggestions
I want a good motherboard that has a easy to use bios and good for overclocking. Again if you know another mobo that you would recommend please let me know.
I have around £750 to spend. Keep in mind that the RTX 3070 is at least £470 which leaves £280.
Thanks
https://linustechtips.com/topic/1274156-need-help/
For the PSU there is the PSU tierlist
it would not surprise me at all if a decent PSU costs well over $100USD, so that may not leave enough for your new mobo.
Edited by Bombastinator
https://linustechtips.com/topic/1274156-need-help/#findComment-14249891
Right now I have-
i7-9700k
GTX 1060 3GB
2x8GB RAM
Thanks
Right now I have-
i7-9700k
GTX 1060 3GB
2x8GB RAM
Thanks
I don't see much wrong with you build other than the GPU you are going to be bottlenecked by your CPU.
https://linustechtips.com/topic/1274156-need-help/#findComment-14249895
are you sure? I just searched for a bit and everywhere said it will be great and there will be no bottleneck.
they say the i7-9700k and the RTX 3070 works great together
https://linustechtips.com/topic/1274156-need-help/#findComment-14249993
