Decide between two 43'' TV
Go to solution Solved by SupaKomputa,
TCL plus : vanilla android.
LG plus : better panel (??), more features (??).
In this black friday I found in my country this 2 TVs at a similar price: TCL 43P615 and LG UN70 43UN70006LA. As you can see my budget isn't the best (both TVs cost 280€) but doing some research I found this two and I can't decide between them.
The main use is watching some TV/netflix/Amazon prime and play some games on the PS4. The room where the TC will be isn't big and there is only sunlight directly on this room about 4 hours during the day ( the room is neither dark nor super bright).
Any help is apreciated as well as another sugestions in this price range! Thanks!
https://linustechtips.com/topic/1274150-decide-between-two-43-tv/
