Killing PSU and 2 CPUs - No Clue why - PLS Help bevor another dies
22 hours ago, toni2 said:Thank you for answering again
1st CPU died with HX, second with AX and new MB (and took the AX with it)
so I checked. behind the mainboard (and back plate) everything is clear. on the part where the CPU is there is a cutout in the cases backplate. I routed a USB cable (isolated) from the AIO through there and the 2x 8 pin CPU power. They are also heavily shielded. The only thing that could cause a circuit could be the fan power cables from the AIO. They were still bound together by those small wire things (with a bit metal inside and covered in plastic). they could have fallen over and caused it.
it sound improbable but definitely possible.
Thanks
**I mean with routed behind the CPU, that the cables just got there between backplate/backplate free area and outer case door. I didn't squeeze anything between MB and backplate .. that would be horrible
*** edit 2: Added a photo. PSU cable already out of the case
Sorry for getting back to you late, as I did not receive a message that you quoted me by replying back to my post. Your reaction to my post was the only thing that made me acknowledge you were still here.
For the fan cables, they should be shielded enough that unless you see a break in the sheathing of the cable, there shouldn't be an issue at all. The EPS (CPU) cables shouldn't be broken at all and can't be the root of your problem unless again like the fan cables, if the cables sheathing is broken and shorting to the case, that would cause issues. I can't think of any other issues at all other than static electricity built up on the components.
