Sleeved Cable
Go to solution Solved by Kleo Yan,
2 hours ago, patken007 said:
How much not flexible. Are they worse than the one that comes with the PSU?
when you sleeve them all on the 24pin. they are pretty hard to bend.
PSU = Corsair AX1000
MOBO = Asus CrossHair VIII Formula
GPU = Asus Strix 3080
I could use some advice.
I want to upgrade my cable with 3 PCIe for my GPU
Also want to upgrade the big 24P ATX AND THE CPU cable.
What brand should i go for?
what should i look for on a cable.
As you can see in the image, they look way more flexible than the one we get with our PSU
https://linustechtips.com/topic/1273270-sleeved-cable/
Hello, you can try this https://cablemod.com/cablemod-launches-diy-cable-extensions/ <- majority will go for this as you can customize the colors of your sleeve.
I personally do them myself and I use paracord compared to PET sleeves, PET sleeves are too stiff and hard to bend. They are not as flexible as paracord.
but choice is yours. you can choose the type of material from Cablemod.
example of paracord and PET sleeves
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14243244
i would check it out and come back to you if have more question
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14243246
@patken007 based on that I would recommend our ModFlex cables for flexibility, and an additional 8-pin PCI-E with our ampere bundles to accommodate the 3 PCI-E cables needed. :)
https://store.cablemod.com/products/?filter_series=c-series-rmi-rmx
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14243247
Hi patken007, I agree with CableMod .. :) those are quality cable sleeves..
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14243256
There are a lot of product options on the link you gave me. Can you pin-point on the product I really need. Also my PC case (Dark Base Pro 900 Orange rev. 2)   I think that black and orange cable would look neat on them. If orange isn’t available, then perhaps black and white.
Also what is the difference between ModFlex and PRO ModFlex
Are these cable extension or direct replacment. I would prefer replacement over extension.
Is it the one you are suggesting?  Pro ModFlex C-Series RMi, RMx & RM (Black Label) Elite Ampere Bundle – CableMod Global Store
Sorry about that many question
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14244280
@patken007 yes you could go with that bundle, or if you don't need as many combs you could go with the bundle that only adds in the additional PCI-E (the kit that goes for $119.80 USD instead. These will be direct replacement cables that plug directly into your PSU and then to the hardware. ModFlex is our softer, more flexible sleeving option. ModMesh is our slightly stiffer option which can make for clean cable routing, but also offers more vibrant colors and some colors are UV reactive (such as white, light blue, light green, etc.). If you wanted orange as an option though, you would need to order from the "Custom PSU Cables" section on our configurator where you could customize with orange in both of our sleeving types. ModMesh orange is a very clean, great look. I've attached a photo of the ModMesh Black/White/Orange from my personal build for reference with aluminum black combs. :)
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14246667
nice build. One last question. Any chance you can show us a picture of how flexible a modmesh can be. I just to see it to made up my mind.
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14248489
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14249042
50 minutes ago, CableMod said:
@patken007 I don't have a photo showing the flexibility, but I've used the ModMesh pro even in ITX builds just fine in the Nano S for example and the EVOLV ITX. :)
Alright i just order my cable ModFelx on the Configurator  [Order #G81522]
I just want to make sure that my 24 pin cable connector look the same as this one, And also my 8 pin pcie connector
https://linustechtips.com/topic/1273270-sleeved-cable/#findComment-14251222
