Budget (including currency): around $2500 CAD
Country: Canada
Games, programs or workloads that it will be used for: Mostly RPG games like Cyberpunk, Witcher 3, Valhalla, Gta
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I so far have purchased the cpu, gpu, and storage
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($449.00) - bought
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($244.99 @ Memory Express)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($179.99 @ Amazon Canada)
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive  (Purchased For $180.00) bought
Storage: Seagate Barracuda 6 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $150.00) bought
Video Card: Gigabyte GeForce RTX 3080 10 GB AORUS MASTER Video Card  (Purchased For $1200.00) bought
Power Supply: EVGA SuperNOVA GA 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($169.99 @ Newegg Canada)
Would like some advice on what kind of cooler i should run for the 5600x and any suggestions for a case.
https://linustechtips.com/topic/1273188-current-build-would-like-some-input/
Stock cooler for the 5600X is pretty trash, don't use it.
For high-end cooling, there are some good sales on the dark rock pro 4 and other high-end coolers, but you really don't need such a crazy cooler for a 65W CPU.
Something like a Hyper212 will work perfectly fine.
Personally, I'm going to pick up a Wraith Prism from eBay for like $25 because I like the fancy lights and the 5600X really doesn't need too much cooling.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
