Budget (including currency): 2500max
Country:  Sweden
Games, programs or workloads
cyberpunk rdr2 etc
that it will be used for: 4K gaming
Other details
PC HELP
So i currently made my first build wich is.
RTX 3080 X gaming trio
AMD RYZEN 9 3900x
Asus strix 850w
ASUS ROG STRIX B450-F gaming.
orsair 16GB (2x8GB) DDR4 3200Mhz CL16 Vengeance LPX
NZXT Kraken X53 240mm
Seagate barracuda 1TB 7200rpm 64MB
Corsair force mp510 240GB
And after some research i have come to the see that the motherboard really isnt good enough for my CPU. So im thinking about swapping it to a Asus ROG X570 Crosshair VIII. Or it this a total overkill when it come to performance gain?
what im currently worried about is that the VRM is really bad and something is going to happen to my PC. And for people who are really good at PC:s i really would love to get some input.
Will anything bad happend if I keep playing games like rdr 2 on max setting and on 4K?
https://linustechtips.com/topic/1273087-need-input-and-help/
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1273087-need-input-and-help/#findComment-14241765
Country:  Sweden
cyberpunk rdr2 etc
Other details
PC HELP
AMD RYZEN 9 3900x
Asus strix 850w
maybe an x570 tomahawk, great vrm, great everything, and it has wifi, so it is ideal
https://linustechtips.com/topic/1273087-need-input-and-help/#findComment-14241768
Country:  Sweden
cyberpunk rdr2 etc
Other details
PC HELP
AMD RYZEN 9 3900x
Asus strix 850w
A X570 Tomahawk would be great. Also try to get 3600MHZ CL16
geometry is hard
b550 > x570
https://linustechtips.com/topic/1273087-need-input-and-help/#findComment-14241791
40 minutes ago, Cyracus said:
so the current motherboard will it work or do you see any problem with it ?
https://linustechtips.com/topic/1273087-need-input-and-help/#findComment-14241889
4 minutes ago, Fyrionez said:
so the current motherboard will it work or do you see any problem with it ? And why those rams are there any difference
 Idk enough about the b450-f to say for sure, the crosshair VIII is definitely overkill though. But I know the b550 tomahawk or the gigabyte board I linked are definitely up to the task of handling a 3900x
For ryzen ram speed yeilds performance improvements running 1:1 ram clock:fclk, 3000 series can do 1800 (3600mhz ram) but can reach up to 1900 (3800mhz ram) for a little more performance. Performance difference varies by workload, difference between 3200 and 3800mhz ram as high as 5% in personal testing. Not really worth the cost of replacing ram
desktop
HTPC
https://linustechtips.com/topic/1273087-need-input-and-help/#findComment-14241970
