low CPU usage while high GPU usage
while playing crysis remastered i noticed that i have 30 fps 1080p high settings which is terrible.
and i saw that i have 18 percent cpu usage while 99 percent gpu.
ryzen 5 3600x
radeon rx 5500 xt
1×16gb 3200mhz ddr4
asus b550 plus tuf gaming
win10 enterprize
could anyone help me out?
https://linustechtips.com/topic/1272989-low-cpu-usage-while-high-gpu-usage/
100% GPU usage at 1080p? What happens when you change the settings a bit?
Primary PC:
PSU tier list
How many watts do I need?
7 minutes ago, ragnarok0273 said:
You might have a GPU bottleneck.
The low CPU usage but maxed GPU makes me think that your GPU can't keep up with what your CPU is feeding it.
but this 5500 xt card is a popular combo with this cpu
is it possible that the gpu is broken and i have to replace it?
6 minutes ago, ZonalThrone said:
I have an rx580, it normally is at 100% but if the cpu usage is low a gpu upgrade was probably what you need, it’s happening to me too, the 580 is paired with a i5-9600k.
just 2 month owning it😑
pc gaming is goddamn complicated these days
ryzen 5 3600x
radeon rx 5500 xt
1×16gb 3200mhz ddr4
win10 enterprize
is it about ram? it says on the stick " xmp 2.0 ready for intel"
and i overclocked it manual
unlikely... also tested this card (in hindsight I'm not sure why, curiosity I guess) it's a very weak card that doesn't really perform as reviews make it out to be (even if most tell you to not to buy it!)
in short, cpu and gpu aren't a good match, your cpu has a lot more potential, and that's what you're see, you need a much more higher end card to make full use of that cpu (in fact, gtx 1070 and up)
yeah... that is normal with that combo, nothing unexpected about it ¯\_(ツ)_/¯
it simply isn't...
to not to be all negative Nancy, I would suggest to return this card, if possible... if you can't do that, then try selling it or something, it's 2020, this card would have been "good" 5- 10 years ago (sorry to say)
https://youtu.be/r2d24PnqiOE
issue as I see it is not at least amds weird pricing, a 5700/xt would make a lot more sense, if it was cheaper... and they continue the weird pricing with the 6800... it seems a bit they're just not learning anything...
-Scott Manley, 2021
it simply isn't...
thanks for the advice
no prob! honestly looking at some benchmarks and stuff I think ideal card would be rtx 2060 / super. it's going to be a bit more pricey, but about doubles the performance compared to rx 5500, and you'll get ray tracing on top of it (whether you care about that or not lol) point is it'll perform well and also be somewhat future proof for a couple of years at least.
I know the 5500 looks enticing, but it's just weak, and I also couldn't get anywhere close to the (still underwhelming) benchmark results floating around... also in my experience amd cards may have higher highs, but also lower lows, it's just not a smooth experience most of the time, especially in newer titles.
the only game where the 5500 xt was able to provide flawless 60fps in my tests was DOA5, a 2012 game... lol. 🤷🏼
-Scott Manley, 2021
