Hello!
I want to buy a new pair of rgb hyperx RAMs and I have some issues eith understanding the compatibility rules between the motherboard, the cpu and the ram. Here is what I have:
Motherboard: Gigabyte B450M DS3H
it supports RGB fusion
4900d70416e06999d3d4cfad1c19db4bde14e4fc_2_690x172.png.c1c4a728e739fcb8feffb64a4997f393.png
CPU: AMD Ryzen 5 2600x (Gpu:1660)
These are the two type of rams I want to buy: 2*8 GB 3a02d6d672a86b46f94b4d6a2e4b1da546f247eb.png.3b09e6ebd61ec97e2b7d8d560b6c0c6b.png
I want to buy the RAM with the highest Mhz possible. These two on the site was labelled that they are supporting RGB fusion 2.0 and I don't know what should I choose. Thanks in advance if someone can help me!
https://linustechtips.com/topic/1272772-hyperx-compatibility-problems/
I would get 3600mhz cl15 of whatever kit you like more
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
1 minute ago, Doomguy____ said:
Sorry I forgot to say that I want 2*8, my bad it's a crucial thing I guess
okay? it doesn't make any difference
AMD blackout rig
2 minutes ago, Doomguy____ said:
I looked it up and I only found it in CL 17. Does that makes any difference? In latency or something?
yes, that's rather shit, 3200 cl15 or 3600 cl16 are usually more available
AMD blackout rig
Hello. I promise this is my last few question and after that I will finally buy one of them. The the last two contestants remaining is one with a:
3200mhz and Cl16 and the second is
3000mhz and Cl15
Which one to choose? And I forgot to ask if they will be working automatically when I will plug them in despite the fact that my motherboard and the CPU has a maximum support MHz of 2933 without overclocking.
3000mhz and Cl15
they're both exactly the same.
and you just need to enable XMP in bios, theres many YT videos on it.
AMD blackout rig
