CPU Overheating
Solved by shone32,
2 minutes ago, Couchy47 said:So my CPU temps are terrible again; 60-70C idle at 70% cpu fan speed.
I think that the issue is more likely to be hardware wise that software. I think you could pick up Thermal Grizzly thermal paste or Noctua NT-H2. They are both around $10 and are way better than the one you got with cooler even if it doesn't resolve the issue.
The other thing I can suspect is bad temperature sensor on CPU itself. I'm not quite sure how you could check that tho.
Check if there is difference between temps in BIOS and those in Windows.
