CS:GO stuck at 60fps?
Legion
Solved: The culprit was a sneaky afterburner profile :(
I've tried everything I can think of.
Vsync on / off
FPS_max 300
Lowering all the settings and disable anything like AA
switching from fullscreen windowed to fullscreen.
Any CS:GO players have any more suggestions?
Also for those who say you can't see more than 60fps my eye was sure able to see it felt wrong which prompted me to boot up afterburner and confirm so :P
Like E-Sports? Check out the E-Sports forum for competitive click click pew pew
Like Anime? Check out Heaven Society the forums local Anime club
I was only living because it was too much trouble to die.
R9 7950x | RTX4090
Vsync on / off
FPS_max 300
Is your display capable of outputting more than 60fps?
Has it worked fine before?
PC Specs:
New Compact Build
CPU: i7 8700k (Delidded)  |  GPU: EVGA GTX 1070Ti ACX 3.0 Black  |  Motherboard: ASRock Fatal1ty Z370 Gaming  |  Case: EVGA Hadron Air
RAM: Corsair Vengeance LPX 16GB DDR4 3000MHz  |  SSD: Samsung 860 EVO 1TB  |  Monitor: ASUS PB287Q
     OS: Windows 10  |  Keyboard: Corsair Strafe RGB  |  Mouse: Logitech G502 Proteus  |  Headphones: Steelseries Arctis 5
Surface Book 2 15"
CPU: i7 8650U  |  GPU: GTX 1060M  |  RAM: 16GB DDR3
check your graphics card control panel that it isnt forced on
My display can only output 60fps but yet I get a few hundred FPS in CS:GO
You have sync forced in Ccc or nvidia control
Vsync on / off
FPS_max 300
Also Rosario To Vampire :D
Check Nvidia control panel. What are your specs anyway? Not that I doubt you can run it but there might be issues with you particular configuration and source.
"If you do not take your failures seriously you will continue to fail"
Yes -.-
Vsync on / off
FPS_max 300
Yes ^ :)
Large pictures from in game settings below
R9 7950x | RTX4090
7970 and a 2500k at 4.5ghz.
I was able to run it before but for some reason after reinstalling the game a few months later its just shit itself and refuses to go above 60.
R9 7950x | RTX4090
I am at a loss as to why that is. Can you watch demos at more than 60fps? You can just download one of the EMS games under the watch tab of the main menu.
I'll give it a try, this only happens on CSGO btw, I've double checked with Starcraft and its all working smoothly.
R9 7950x | RTX4090
Nope still stuck at 60 oh well no CS GO for me :(
R9 7950x | RTX4090
Are you running software like MSI Afterburner or anything that can limit FPS?
I am using afterburner but its applying a 120fps limit not 60. (120 was a stupid limit I had to use because skyrims physics doesn't like anything that isn't multiples of 30 -.-)
I've checked a few other games today trying to debug this.
EDIT found a CS:GO profile under afterburner configured for 60fps cap.
Jesus christ I certainly didn't make it who did :(
R9 7950x | RTX4090
