2 hours ago, Questionare101 said:
Hi there I was wondering if a 650 Watt PSU would be enough for my system:
CPU: Ryzen 5 2600X
GPU: Either a GTX 1070 or RX 580
HDD: 1 TB 7.2K RPM WD BLUE
RAM: 32 GB of DDR$
CASE: Montech Flyer - Black/Micro atx
FANS: 3-5 CASE Fans
Mobo:Asrock b450 pro4 am4 mATX
What kind of 650W?  If it's like a Raidmax or Coolmax, then the answer is automatically, "no".
https://linustechtips.com/topic/1272351-enough-power/#findComment-14236807
But what about other *max-es ? Gamemax ? Supermax ? Megamax ? Enermax ? What's up with all these firework makers feeling a need to put 'max' in the name ? Corsair RGB-max when ? 😄
Tag or quote me so i see your reply
https://linustechtips.com/topic/1272351-enough-power/#findComment-14239141
