1 minute ago, Corie said:
Hi i have a PC case and the fan has a Molex connector and IDK what to hook that too. The motherboard, PSU IDK somone please help.  (And there is a Sata cable that comes from my case IDK  if thats for my front fan or what)
Your PSU should have molex power cables.... So you just plug them into that.
Now i jest realized that one of my PSU cables for the molex fan has what looks like a Motherboard fan header on it so would i plug it only in the motherboard or the PSU too?
The PSU def does not have a fan header plug...
It may be a floppy power plug or something?
