Budget (including currency): $1300
Country: US
Games, programs or workloads that it will be used for: Gaming, VR, 3D modeling, general productivity.
Hi, I have never biult a PC before and was wondering what you guys thought of my parts list. I already own a kit of 32g trident z Neo and planing on getting the rest soon. I am planing on going with the stock cooler but if you have any suggestions that would be great. I know about 5000 series but need the extra cores of the 7. Also if you have any tips for biulding then that would be great. I also need a monitor so if you have any ideas I would appreciate it.
https://linustechtips.com/topic/1271840-first-pc-help/
A stock cooler would be fine but you will run a little hot and you won't get any overclocking done.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1271840-first-pc-help/#findComment-14232983
After market cooler is a nice to have but in most cases the stock cooler is fine.
Otherwise, nice build! Post pics when it’s done!
Potato Revamp
CPU: AMD 5900x || GPU: nVidia RTX 3080 || RAM: 32gb Trident Z Neo CL16 || Case: Fractal Torrent Compact || CPU Cooler: Scythe Fuma 2 || PSU: Corsair RM850 Gold || Storage: ADATA SX8200 Pro (1TB), 2x Samsung Evo 870 (2TB)
https://linustechtips.com/topic/1271840-first-pc-help/#findComment-14233006
