I'm having a problem with my ram running at full speed without my computer going into a boot loop. I have 4 sticks of 3200MHz at CL-16 but after it goes into a boot loop it changes it to 2400MHz. I was able to get it to 2666MHz. Is this due to the motherboard or something else entirely. System specs: Ryzen 5 1600af, ASUS B450-f gaming motherboard, 4 sticks of delta t-force 3200MHz ram, GTX 980TI, and EVGA 1000 W 80+ gold. Can someone please help?
https://linustechtips.com/topic/1271486-problems-with-ram/
Did you set your ram voltage to 1.35v?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1271486-problems-with-ram/#findComment-14230279
Early Ryzen Chips had weak IMCs in them and hated 4 sticks of RAM.. this is likely your problem. You can try enabling XMP and then turn up the SOC voltages in the BIOS as well. You're safe to go up to 1.2v 24/7 on the SOC.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1271486-problems-with-ram/#findComment-14230280
I’m using the xmp profile but it’s called something else on the board. The default voltage is 1.35. Should I try a new cpu?
https://linustechtips.com/topic/1271486-problems-with-ram/#findComment-14230477
DOCP is what its caused on ASUS boards. Increase your SOC Voltage to 1.15v and see. If that doesnt work, try with just 2 sticks.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1271486-problems-with-ram/#findComment-14230555
I tried it and I already knew it would work with just two sticks but it started the boot loop again at that voltage. I was thinking of upgrading to a ryzen 7 2700x. Would this cpu work out better than the 1600af with this ram?
https://linustechtips.com/topic/1271486-problems-with-ram/#findComment-14231539
