you need to list the timings in the first place, and btw, lower timings are better.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1271202-help-ddr4-3200-memory/#findComment-14228223
Considering there's like a hundred different variant of these... we don't know.
If they both have the same timing right out of the box(Guessing CL16 here?), they are going to perform the exact same so go with whichever is cheapest.
https://linustechtips.com/topic/1271202-help-ddr4-3200-memory/#findComment-14228227
as @TetraSky said since theyre the same timings go with whatevers cheapest
AMD blackout rig
https://linustechtips.com/topic/1271202-help-ddr4-3200-memory/#findComment-14228234
The crucial one, just because Crucial is owned by Micron and Micron more likely to not suck at this speed and timings. Meanwhile Patriot can use chips with little tuning potential (like Hynix MFR) because it can buy from anyone and what goes onto the stick depends on what arrives at the factory that day (because 3200 16-18-18-38 is easy to hit)
Desktop benching:
https://linustechtips.com/topic/1271202-help-ddr4-3200-memory/#findComment-14228235
