is this power supply good?
dav94
I bought this power supply to use with a future rx 6800xt in my build with my ryzen 5 5600x
https://www.google.com/amp/s/www.newegg.com/amp/be-quiet-straight-power-11-850-watt-platinum-850w/p/1HU-004H-000G5
Just now, BunchyPants said:
why if i may ask?
We do not know much about it. it is fully modular and 80+ gold but that does not mean anything. It is not in the tier list, it is on the spreadsheet but nothing is there. Probably because there are no real reviews about it.
@Juularwill tell you if it is decent or not.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
yeah its the replacement i will get from the store for my evga 700w 80plus. I had u constant buzzing noise under full load with the gpu
1 minute ago, jaslion said:
It's a little reviewed unit. It's ok but should not be used for your system.
yeah like i told this is the one the shop will be sending me now.
