1 minute ago, Pigowl said:
Hello I’m using the MSI b550 a-pro it looks like the ssd and heat sink is weird, seems like the ssd is too small. Any tips?
Just screw the heatsink on overtop of it. It will be fine.
CPU: AMD Ryzen 7 5800x
Motherboard: Asus ROG Strix X570-F Gaming
RAM: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3600 CL16
Graphics: Zotac GAMING Trinity OC GeForce RTX 3090(Flashed with Gigabyte 390W BIOS)
SSD: Samsung 970 EVO NVMe 1TBx1, Samsung 970 EVO NVMe 512GBx1, Samsung 860 Pro 256GBx2 RAID0
PSU: Corsair RM1000x 80+ Gold Case: NZXT H710 (custom panels)
Monitor:  Alienware AW3420DW Curved 34" WQHD 3440 X 1440 120Hz Ultrawide, Pixio PX329 32" WQHD 165Hz,
Keyboard: Logitech G915 TKL
Mouse: Razer Basilisk Ultimate Wireless
Cooling:
EK-Quantum Vector Trinity RTX 3080/3090 D-RGB
EK-CoolStream SE 360 (Slim Triple) x2
EK-Quantum Kinetic TBE 200 D5 PWM D-RGB
EK-Quantum Momentum ROG Strix X570-E Mono Block
12/16mm Tubing
https://linustechtips.com/topic/1270834-ssd-help/#findComment-14224956
4 minutes ago, Pigowl said:
Ok thanks!
You can also just add a standoff into the appropriate hole if you're worried about it coming loose. mobo should have come with spares, or steal the one from that bottom nvme slot
Cooling:
12/16mm Tubing
https://linustechtips.com/topic/1270834-ssd-help/#findComment-14224965
