Selecting Cablemod cables for Ion + 860w
13 minutes ago, FeIIex said:Went off the PSU tier list, it was the highest ranked that was in stock and not over 300 CAD
Ok. The Fractal PSU is made by High Power. And unlike a lot of the more common brands, the pinout doesn't follow a common pinout. e.g. It's not the same as Corsair, Seasonic, etc.
And extensions are a bad idea because they add another 30 to 45cm of cable that adds resistance, as well as the additional connector, and needs to be hidden inside an already small case.
I have a Meshify C and trust me, it's not easy to jam that much cable behind the motherboard.
Not sure why PSUs are over 300 CAD up North. Though 860W is probably way more power than you need too.
Down here (U.S.) you can get a Corsair RM850x or Seasonic Focus 650W for less than $230 (which is about 300 CAD).
Either of those you can also get custom cables for pretty easily.
