Budget (including currency): Up to you but i dont want to overspend on non esential stuff im not an enthusiast euros
Country: Greece but you can give any eu shops im fine with that :)
Games, programs or workloads that it will be used for: streaming, gaming(AAA titles) 4k video editing for youtube
Other details I want to start making gaming  taht will be recorded on highest setting and 4k and live streaming on twitch also record and edit 4k content. I don’t care about high fps as long as it wont go below 60 im more than happy and please include a monitor and im ok with parts that dont have rbg I want the best performance but without spending 1900 for a 3090(yes it costs that much in greece)
Thats pretty much it thank you for your time :)
https://linustechtips.com/topic/1268322-need-help-with-build/
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205150
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205151
Just now, Markos159 said:
Thank you for your time and btw do you think it will be any beneficial gatting 32 gb of ram i have read that for 4k video editing 32 is beneficial
You will be needing 32GB of RAM for 4k video editing and streaming. :)
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205155
3 minutes ago, Markos159 said:
Awesome and should i get the 5800x or stick with the 5900x and can you recommend any monitors please
The 5900x is probably the second best CPU on the market. (5950x is better)
"If you need 8 cores, you need 12 cores. And if you don't need 8 cores, go with 6 cores." Linus Sebastian 2020.
If you ok spending that much money, then the 5900x is what you should get, if you want to spend a little less, then look into the 5800x and see how much of a performance difference you would get.
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205167
For monitors, I really don't know much, but I'm happy to give you my two cents! If you want a 4k monitor, you will need to spend upwards of $450 for a 4k monitor with a decent refresh rate so your games will look decent.
The Asus ROG Swift PG27UQ is one of the best 4k 120hz monitors out there, but its pretty expensive.
I recommend the Asus ROG Strix XG27UQ or the 27'' UltraGear 4K UHD Nano IPS 1ms 144Hz G-Sync Compatible Gaming Monitor from LG.
I don't know much about monitors, but that is what I recommend! Please believe someone else over me :)
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205183
There is a monitor that caught my attention can you check it out and tell me what you think aboutit https://euro.evedevices.com/pages/full-specs
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205252
Ive never heard of the website (probably cuz im in the US) but that looks great, just keep in mind that its a 1440p panel and not 4k. I would watch some reviews on it tho.
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205289
19 minutes ago, Markos159 said:
They do have a 4k one
Hmmmm. I always watch reviews for whatever I am about to buy, and I always recommend others do the same. But if you feel confident, then yeah! it looks great!
https://linustechtips.com/topic/1268322-need-help-with-build/#findComment-14205431
