Hi, I recently made a nas for my father and it is like a lenovo think centre m82 so if anyone familiar with it know that it is like the size of 3u or 2u chassis so I like want like a rack and want to put that and like a switch and the router inside it so that it gives a clean look. and my budget for the same is really low like 30 or 40 bucks for the rack. I currently live in India so please help me with the things available in India. Thanks
https://linustechtips.com/topic/1267868-server-organisation-and-rack-help/
Lenovo ThinkCentre M82 is a SFF Desktop chassis, not rackmount (I couldn't find rackmount version of that). There is no easy way to mount it in a standard rack.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
yes I know I have like a tray that can make like a mount for the system with rails and make it rackmounted
I have the same PC but I am using it as ESXi server and I would say it is a 2u
i don't think you can get a rack for that amount. here in the uk, just the shelf for the rack costs like £25-30. the server racks seem to cost like £200. i don't know why TF it costs that much lol, thats the only reason I don't have one. I just bought a little computer desk instead. im sure you can get something similar to a rack for 40$ for cheap af, but you never know, they might be way cheaper in India than they are over here
nah man the price is all same everywhere either the racks are out of stock online or they are priced like 20000 rupees  same as like you mentioned but I want a solution which is cheap if anyone can help me I can build a custom design.
cheers
cheers
what i did is just put startech rubber case feet on components and place them on top of each other, ive got the server computer at the bottom, then a laptop on top of it with rubber case feet, and 2 switches on top also with rubber case feet, and planning to put a old router used as an AP on top of there too. its on a cheap computer desk that you can roll around was like £20
can you help me showing how you have done it. It can help me get a better idea of what can be done
anyone please help
16 minutes ago, Sukrit Kumar said:
anyone please help
Mine isn't on a rack.. sorry :(
So, you're in India. Use that famous Indian ingenuity: go to a local metal working shop, describe what you want (making a drawing on paper will probably help) and have it fabricated for you at rockbottom prices :) It may not look as sophisticated as a Dell or DSI rack enclosure, but it'll fit your budget a lot better!
HTH!
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
HTH!
Hi, thanks for the response but apparently it is really hard to find these kind of people and it is even harder in this time. Like if anyone can help me build it and maybe give some ideas. thanks
HTH!
also if anyone of you guys can help me from where can I look for like acrylic, mdf and tools online to buy.
