Mobo Possibly Not Getting Power?
By
JSei
in Troubleshooting
in Troubleshooting
Solved by SavageNeo,
1 minute ago, JSei said:Yeah it is mounted in the case. That is something else I didn't think to check on is that all of the standoffs are mounted correctly. I will try running it on just the mobo box as another test.
yes do that. if it runs there soemthign is short circuiting your mobo in the case.
toxic_worper ·
Posted in New Builds and Planning8 -
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
