Upgrade help needed
Go to solution Solved by Fasauceome,
Budget (including currency): 5000kr (stretchable)
Country: Sweden
Games, programs or workloads that it will be used for: CSGO, Warzone
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm helping my friend upgrade a PC not sure what to pick, He will play 1080p probably 60hz, stuff he will keep from current PC HDD, SSD Kingston A400 (just bought), GPU, MSI GeForce GTX970 Turbo 4G
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1267393-upgrade-help-needed/
Its a bit over budget but is a good balance of parts. It also allows for upgrades to the GPU later. You can drop the RAM down from 3600 mhz if the budget calls for it.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14197089
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14197095
Just now, drexTech said:
What what OS?🤔
How is that relevant?
Reminder⚠️
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14197119
6 minutes ago, Fasauceome said:
Hmm looks good actually would it be possible to get an ATX case with maybe a window panel or no? Just for more options
Reminder⚠️
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14197123
Primary PC:
PSU tier list
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14197139
Reminder⚠️
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14197149
@FasauceomeI forgot to ask one thing would the mobo work out of the box with the CPU?
Reminder⚠️
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14198424
all MAX versions of MSI motherboards are guaranteed to work with 3rd gen Ryzen CPUs.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14198432
Okay that should be good for me then paired with that mesh case deepcool something
Reminder⚠️
https://linustechtips.com/topic/1267393-upgrade-help-needed/#findComment-14198464
