Old case cooling
Solved by CommanderAlex,
4 minutes ago, MegaProject said:How should I position them then?
So you don't have a 90mm fan in the rear at all? I would then just have the faster 120mm (2200)RPM fan in the front with the slower 120mm (1450)RPM fan on the side. I would not have any of these fans as exhaust, just purely intake with the pressure inside the case hopefully go out the rear that is open and the one 120mm side fan spot.
