Hi,
I have a Corsair Carbide 678C case and was wondering I'm about install my noctua cooler when it comes in the mail this evening and want to finish this PC completely today and had a question about the front I/O. I have the Asus ROG B550 F gaming(WiFi) motherboard and included a couple of pics of the board itself from the manual and the connectors on from the corsair case manual. Where do I plug in these ports into? I've already got the Audio, but not sure about the USB ones. Thanks for any help.
https://linustechtips.com/topic/1266005-connecting-front-io-panel/
USB 3.0 plugs into U32G1_12, which is located under your 24-pin power connector. There is no USB C header.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
ok thank you for quick response, its fine on the usb c port my graphics card has one on it. thanks again for help.
