16 minutes ago, Ahsan Ghauri said:
I have gigabyte ga-b85m-hd3 mother board but i am not able to connect to network lan port blink orange light. What should i do?
A blinking orange light usually indicates a gigabit connection. You should probably check your network configuration.
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14184799
  1. Download network/LAN drivers from the motherboard support page. Then uninstall the old drivers and install what you downloaded.
  2. Unplug the ethernet cable at both ends and plug them back in. Make sure they make a snug fit.
  3. Change the ethernet cable to CAT5e or better.
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14184856
I tried uninstalling old drivers and downloaded new ones from their website but internet is not working
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14185015
Has the ethernet connection worked before or are you connecting it to the PC for the first time?
Try the tips suggested here.
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14185173
28 minutes ago, Ahsan Ghauri said:
I am connecting first time
Are you connecting directly to the router/switch?
What kind of ethernet cable are you using? Cat5/Cat5e/Cat6/etc? Is it a pre-made cable or one that you crimped yourself?
Did you test with another cable altogether? What about another port on the router/switch?
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14185593
Cable work fine i also switched port on the router
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14185706
So you used the existing cable on another computer and got online OK?
Did you follow the steps outlined here?
I did. One more thing if install pci network card the internet speed will be lower or latency etc? Or it will work fine?
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14186045
It should be fine, provided you install the proper drivers.
As it concerns latency, that will depend on multiple factors, but those are usually not in your control when using a wired connection.
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14186152
Which one is best usb ethernet adapter or pci network card?
https://linustechtips.com/topic/1265820-i-need-help/#findComment-14186254
