Lights on my ROG Z390 E-gaming motherboard suddenly stopped working. Everything boots up and works normally, but the RGB is off all the time. It is synced, it is set to a mode that has color, but it just doesn't work. My other ASUS product (Graphics card) lights up without a problem, and HyperX RAM also lights up.
Another thing is that the front light of my case (that shows if PC is on or off) doesn't light up either.
https://linustechtips.com/topic/1265599-rgb-lights-aura-sync/
