Budget (including currency): 2,500 USD
Country: USA
Games, programs or workloads that it will be used for: Games
Other details Parts:
Case - https://www.newegg.com/p/N82E16811553024?Item=N82E16811553024
Motherboard - https://www.newegg.com/asus-rog-crosshair-viii-hero/p/N82E16813119110
Processor - https://www.newegg.com/amd-ryzen-9-3950x/p/N82E16819113616?Item=N82E16819113616
CPU Cooler - https://www.newegg.com/corsair-liquid-cooling-system/p/2KY-001T-00027?Item=2KY-001T-00027
SSD - https://www.newegg.com/seagate-firecuda-520-2tb/p/N82E16820248109?Item=N82E16820248109
Graphics Card - https://www.newegg.com/gigabyte-radeon-rx-5700-xt-gv-r57xtaorus-8gd/p/N82E16814932235?Item=9SIAD7HC2S2752
Power supply - https://www.newegg.com/corsair-ax1600i-cp-9020087-na-1600w/p/N82E16817139226?Item=N82E16817139226&quicklink=true
https://linustechtips.com/topic/1265213-build-help/
Maybe get the 970 evo 2tb since its $200 off?
https://www.amazon.com/Samsung-970-EVO-Plus-MZ-V7S2T0B/dp/B07MFZXR1B
Edit: I have had good experiences with the 500gb model
https://linustechtips.com/topic/1265213-build-help/#findComment-14180363
Use pcpartpicker.com to build The list. It can be restricted to particular merchants if desired.
The case window is acrylic. For the money you should be looking at a case with a glass window. Acrylic scratches easily.
Wait a couple of days. New AMD cpu are expected Nov. 5. It's possible that they may be better than the current best for gaming Intel 10xxx.
Use an m.2 NVMe or at least SATA ssd. Inexpensive and much faster than hdd, even hybrid models.
The psu is a poor choice.
PCPartPicker Part List
CPU: Intel Core i7-10700K 3.8 GHz 8-Core Processor  ($379.88 @ Newegg)
CPU Cooler: Asus ROG Ryujin 240 RGB AIO 121.8 CFM Liquid CPU Cooler  ($235.99 @ Newegg)
Motherboard: Asus ROG STRIX Z490-A GAMING ATX LGA1200 Motherboard  ($249.99 @ Newegg)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($144.99 @ Newegg)
Storage: Crucial P1 2 TB M.2-2280 NVME Solid State Drive  ($224.99 @ Newegg)
Video: ASUS TUF Gaming GeForce RTX 3080 DirectX 12 TUF-RTX3080-10G-GAMING...  ($699.99 @ Newegg
Case: Fractal Design Meshify C ATX Mid Tower Case  ($98.98 @ Newegg)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($144.99 @ Newegg)
Total: $2186.81
Generated by PCPartPicker 2020-11-04 20:25 EST-0500
https://linustechtips.com/topic/1265213-build-help/#findComment-14180459
