I need to get more Memory (at the moment It's Corsair Vengeance LPX 32) but unsure about a couple of things ... 1) Does it need to be the same type (Co. / speed), 2) same amount?
The model No. I have I think is 163301 looking at CMK32GX4M2B320016W as I think the white would be nice.
https://linustechtips.com/topic/1265081-more-mem-same-type/
It should be same frequency or higher, same memory timings as much as possible. Same voltage as much as possible.
Motherboard will pick the frequency all sticks support (if 2 sticks do 3200 Mhz and 2 do 3600, they'll all run at 3200 Mhz)
Motherboard will pick the timings all sticks support (the looser/higher ones, ex one supports 15-16-15 and other 16-18-16, all will work at 16-18-16)
Some motherboards will have difficulty keeping high frequency with 4 sticks of memory. For example, your motherboard may work with 2 sticks at 3600 Mhz, but may only be able to work at 3200 Mhz with 4 sticks, even if all sticks indendently or in sets of 2 can work at 3600 Mhz.
It depends on the quality of the motherboard, how well it was designed, and other things.
Also, ideally you shouldn't mix SS and DS sticks/pairs of sticks, but most 8GB or higher sticks are DS so it's probably not a big concern.
https://linustechtips.com/topic/1265081-more-mem-same-type/#findComment-14178731
