they are asking what is the latest protocol from microsoft for file and printer sharing. options are netbios/netbeui, cifs,netbios and wins. i was thinking it was CIFS but i would like a more professional opinion thanks guys!
Project black out: cpu: athlon x4 750k @4.7ghz, Mobo: asrock fm2+ a55 vg3+, ram: 1x 8gb hyperx 1866mhz, video card: 1x saphire radeon r9 270x, Storage: 1tb hdd ssd in the future,  cooling: 2 noctua 120mm fans 1 on rad one front intake.
https://linustechtips.com/topic/126484-networking-class-help/
Google?
google has forsaken me I found the 2 it could be but I couldnt find what one is still used thank you for the reply though! :)
https://linustechtips.com/topic/126484-networking-class-help/#findComment-1682380
Found this
"Microsoft SMB Protocol is most often used as an Application layer or a Presentation layer protocol, and it relies on lower-level protocols for transport. The transport layer protocol that Microsoft SMB Protocol is most often used with is NetBIOS over TCP/IP (NBT)"
So it sounds like the protocol used for presenting the data is samba(cifs) but the underlying protocol for transporting the data is netbios. So I guess the technical answer is both? Best guess would be cifs though.
https://linustechtips.com/topic/126484-networking-class-help/#findComment-1682414
thanks for the help I LOVE LTT COMUNITY <3(and yes i cant spell)
https://linustechtips.com/topic/126484-networking-class-help/#findComment-1682437
