CPU Power Throttling
Go to solution Solved by Nikkelz,
So, I think I just fixed it... I turned off Gaming Mode in MSI Dragon Center and all appears to be working fine with no throttle. I'll update this thread if power throttling continues
Hey everyone!
Looking to get some guidance on why my CPU is power throttling. This is a fairly new build that I put together and as of today, the CPU is power throttling any time I open a new game down to 800 mhz. I've reverted my OC back to stock to see if there was a config issue with my OC, which always has been stable and no issue.
The specs:
i7-10700k (reverted to stock, previously was at a 5.0ghz OC)
850w PSU Corsair HX
H100i AIO
MSI 3080
32gb of Vengence Pro Ram 3200mhz
Asus Strix-E Motherboard
Any suggestions or tips would be greatly appreciated!
https://linustechtips.com/topic/1264827-cpu-power-throttling/
Power limit is under "advanced tuning" section and there are two of them (and a time for short something something). What numbers are in those sections?
Desktop benching:
https://linustechtips.com/topic/1264827-cpu-power-throttling/#findComment-14176907
