So, my CPU fan has been stuttering, so I removed it, used some compressed air to get dust out and put it back in, and then... it didn’t help, so I got my friend on, and he told me to go into BIOS and up the frequency, then my phone died so I upped it by 50, and after that, it did the opposite of help, it I think put my pc in a deadlock, now it won’t send a signal to my monitors making it where I can’t fix the frequency, and I need to know if there is some way of fixing it.
https://linustechtips.com/topic/1264611-problems-with-pc/
1 minute ago, Sakuriru said:
  1. Never take advice about computers from your friend again; they're giving you awful advice.
  2. You're going to need to reset the bios to factory settings. Look into your motherboard manual for something like "CMOS reset" or something like that. Modern motherboards have a button for it, but cheaper or older models will actually use a jumper. Follow the instructions to reset your motherboard to manufacturer settings, this will return your cpu clockspeed to normal.
  3. Don't adjust your clock speed anymore until you know what you're doing.
  4. Buy a new cpu cooler. Noctua makes some pretty good ones.
I don’t have a manual for my motherboard and it’s a pretty old motherboard
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175033
Fans are cheap.... well non rgb sleeve bearing fans are cheap anyway.  Rgb fans are ridiculously expensive.  Maybe invest $6 in a cheap fan to test with.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175034
The internet may.  It’s great for stuff like that.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175039
1 minute ago, Quakey said:
Is there a way to know what motherboard I got?
Should be written on it somewhere.  If it’s a prebuilt the make/model of the prebuilt should be enough.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175055
Is this my model?
Yep.  Not a prebuilt.  Type that into a search and you should come up with something.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175057
Myself I generally clear cmos the really old fashioned way: I unplug the thing from the wall and pull the cmos battery for 5 minutes or so.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175062
4 minutes ago, Quakey said:
This is a prebuilt, it’s from cyber power, got it like last year.
But it’s built from consumer parts.  By prebuilt I mean HP or Dell or something.  They commission motherboards for their systems and the model is often not marked in a useful way.  You have a manufacturer and model.  How is cyber power selling 87 series boards newer than 2015?
update 78 not 87.  Transposed numbers derp.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175070
So it says clear cmos with a flat head screw driver to short 2 pins, which has got me stumped
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175088
That’s one way and has the advantage of being instant.  A screwdriver in this case is acting as a convenient piece of flat conductive metal of the right size.  That it can drive screws is coincidental.  The idea is to momentarily short the cmos pins.  Find the two cmos pins and bridge them (what the screwdriver is for)
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175099
Can you help me find them, I don’t know much about PCs.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175103
5 minutes ago, Quakey said:
If I had to guess I’d say the cmos pins are probably the set with the black insulator on the bottom.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175104
If you can’t find them there should be a flat button battery on the motherboard somewhere.  If you pull it and wait for the cmos to lose power and die you can clear the cmos that way.  The cmos battery is held in in many different ways and may require some sort of unclipping.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175110
Also should I turn the pc off or keep it on?
Off off off!  Like actually unplug it and wait a bit for residual capacitor energy to drain.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175112
3 minutes ago, Quakey said:
The ones right under the clr and above the line of white pins?
Yah.  I’m just guessing though.
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175114
Is this the button thingy
https://linustechtips.com/topic/1264611-problems-with-pc/#findComment-14175124
