1 minute ago, AshTraitor said:
Yep
Alright
I have a story for ya mate
I spilled a sh*t amount of coffee on my laptop and my audio chip was destroyed
This info helps. ;) An external DAC will help you get you a functional audio output, given that your USB ports work, but you wont get your speakers back that way.
https://linustechtips.com/topic/1264484-help/#findComment-14173982
Aight
And what type of ex dac u will recommend for buying?
https://linustechtips.com/topic/1264484-help/#findComment-14173988
2 minutes ago, AshTraitor said:
Aight
What ever you want mate. 1 $1 AliExpress USB soundcard will get you audio out (and in), a Schiit stack will get you more or less excellent audio for your $400 headphones. Really depends on what you need.
https://linustechtips.com/topic/1264484-help/#findComment-14173998
I want to use my airpods pro with the laptop
im not the audiophile
im just a netflix dude
https://linustechtips.com/topic/1264484-help/#findComment-14174007
These are wireless and have their own built in dac. All you need is a functioning Bluetooth transmitter on your laptop.
Edited by geo3
https://linustechtips.com/topic/1264484-help/#findComment-14174018
5 minutes ago, geo3 said:
These are wireless and have their own built in dac. All you need is a function Bluetooth transmitter on your laptop.
Aight mate
lets go little specific
my shit is Xiaomi Mi Notebook Pro Gtx
best I’ve ever had
and it have it’s own Bluetooth 5.0 I believe
sooo
will it work?
https://linustechtips.com/topic/1264484-help/#findComment-14174044
