I need help, My pc has been working fine for months now, it is my first build, and i could run minecraft at 60fps no problem 32 chunk render distance at all times. and I used to get higher frames in all games the frames just seemed to drop> this happeed a short time after i tried to oc my moniter with a friend it didnt work so i reset my setting and uninstalled the oc software (CRU i thinkl ). I dont thonk that is related but idk.  I just get less frames then before and i have no idea why please help!
MY specs
Cpu: r5 3600
Gpu gtx 1660 super
ram 8gb ddr4 3600 (  secend stick is on its way back from a friend )
mother bored : a320m s2h
500gb ssd
2tb hhd
https://linustechtips.com/topic/1263431-help-with-random-problems/
