12 hours ago, Caroline said:
You can literally get a case, a PSU and a cooler for much less and build it yourself, you're not assembling an onboard nav computer for the flying carrot that's going to Mars, it's just a PC, even I can do it and trust me I can be really dumb sometimes.
Just don't think "oh this is gonna break", if you don't know something read the manuals, you know, those booklets nobody cares about? they contain useful info and even drawings.
Thanks Caroline. It's just a tad daunting embarking on a build with relatively expensive parts and being a novice but yeah that case is so expensive but cable management seemed so sweet
https://linustechtips.com/topic/1263188-nzxt-h1-case/#findComment-14165133
If your looking for a SFF(Small Form Factor) case then the NZXT H1 is  agreat buy - I have one.
but if your not bothered about size then it will be cheaper to build using mid ATX cases
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1263188-nzxt-h1-case/#findComment-14165179
For what you are getting it really isn’t expensive.   Keep in mind these are small quality parts.   Gold rated PSU, 140MM AIO cooler and a great case.
Tell my tale to those who ask. Tell it truly; the ill deeds along with the good, and let me be judged accordingly.
https://linustechtips.com/topic/1263188-nzxt-h1-case/#findComment-14165935
It is a very nice looking case!
I showed it to my daughter for her graduation PC build, and she really liked the look of it.
Granted, I plan to get the mesh sided one to keep it cooler.
But back to your other issue of this being your first build.
Instead of buying a really great SFF case, head to your local thrift store or if you can an e-cycler.
See if they will give you a desktop that you can take apart and put back together a couple of times.
This way, you have an idea on how some parts are tougher than you think and which ones are delicate.
If you get it to run, great, play around with it.
THEN, spend your money and follow along with How to Build your PC videos.
If you haven't watch Scrapyard Wars, then I recommend that, to see the fact that you can build something pretty nice, for fairly cheap.
But just think of it in reverse. This way you can get familiar with the internal components of a PC.
Before you spend a good portion of money on the final system you want.
OK enough of my rambling.....
My 2020 Upgrade: CPU: Ryzen 5 3600; MB: MSI X570 Tomohawk WiFi; Memory: G.Skill Ripjaws V 32GB 3600 MHz; Case: Lian Li Lancool II Mesh Performance; PSU: Corsair RM550X 80+ Gold; Storage: WD Blue 500GB SSD; Seagate 4TB Compute HDD; Monitor: GIGABYTE G34WQC 34" 144Hz Curved Gaming Monitor, 3440 x 1440 VA 1500R Display
Previous Components Still Using: GPU: MSI GTX 1070 (bought Used); Storage: WD 3TB Green HDD,WD 1TB Black HDD, SanDisk SSD PLUS 240GB
Previous Monitor I want to VESA mount: LG 29UB55-B 29" Ultrawide 1080p 60Hz IPS
https://linustechtips.com/topic/1263188-nzxt-h1-case/#findComment-14179573
