9 minutes ago, AndreiArgeanu said:
Android Studio does have version for ChromeOS and Linux so you should be able to beginner maybe even close to intermediate level android programming. But if your budget allows I would suggest picking up a higher end laptop to future proof.
Thanks. I break laptops before they get outdated. Which is why I'm looking at cheap ones. I broke my $2k macbook after owning it two months. Yea I am just making simple apps. Not doing anything professional.
https://linustechtips.com/topic/1263151-chromebook-help/#findComment-14163009
