So I’m planning on building my first PC in the next 2-3 months. I have a list of parts but I was thinking if there was better options to go for. My budget is under 700€ Also I’m very new to the whole PC thing so I really need help Also the PC would pnly be used for gaming.
For the CPU I have a Ryzen 3100. I don’t need more cores and I believe this is an ok cpu.
I have 16GB of 3200 memory
Then I was thinking whether to go for an rx 5500 xt or a 1660 super. I’m a bit worried about the 6GB of vram in the 1660 super and if it would be enough. Also if there are better options in the 200€ range
Also I have a 600W 80+ Bronze PSU from EVGA. Is 600W enough or could I save some money by going for a 550W PSU or lower.
https://linustechtips.com/topic/1263034-first-pc-build-help/
7 minutes ago, mixuboi69 said:
a 1660 super
a 1660 super is much better than the 5500xt, despite its lower vram. 6gb vram is  enough for most games at 1080p and 1440p.
as for psu, a corsair cx550 would be the best choice for your budget and build, if you can find one.
what about motherboard?
https://linustechtips.com/topic/1263034-first-pc-build-help/#findComment-14161976
For the motherboard I'm thinking of going for a msi b450m pro-vdh max or an asrock b450m pro4. The asrock one would be about 10€ more expensive but I believe it is a much better board so probably the asrock b450m pro4
https://linustechtips.com/topic/1263034-first-pc-build-help/#findComment-14161989
