When ever I boot my PC, it gives me a CPU fan error warning. I use an AIO pump, and it says its working fine when I open the BIOS. This started happening after I overclocked. I have a Ryzen 5 3600 overclocked to 4.7GHz on a B450 motherboard. Please help, its annoying to have to go into the BIOS every time I boot my PC. I changed nothing in the BIOS except the overclock and RAM profile.
https://linustechtips.com/topic/1261591-cpu-fan-error/
What is the error (pic maybe?) and what do you do in bios?
Have you restored the bios to defaults at this point and have you checked cabling to be sure nothing came loose?
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
https://linustechtips.com/topic/1261591-cpu-fan-error/#findComment-14149518
I wasn't getting the error before the overclock. I restored the BIOS to default and then overclocked my CPU to a stable 4.7GHz and overclocked my RAM. Then I started to get the error. Everything is plugged into the motherboard properly. I'll restart my PC to get a pic for you.
https://linustechtips.com/topic/1261591-cpu-fan-error/#findComment-14149526
Does the error go away if you restore bios to defaults and leave it that way for testing?
Family machines
https://linustechtips.com/topic/1261591-cpu-fan-error/#findComment-14149553
4.6ghz? with what voltages? with 1.5+ voltages it is possible with under 1.45V not possible. you probably messed up the overclock
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1261591-cpu-fan-error/#findComment-14149558
Do you have anything plugged into the CPU fan header? Usually that's the board complaining it isn't getting a tach input from the one fan it expect to always have (depending on the board, you may be able to disable/ignore it).
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1261591-cpu-fan-error/#findComment-14149599
