Thermal paste question
Go to solution Solved by Fasauceome,
1 minute ago, Enxquity said:
I currently have some worn out old thermal paste on my cpu and im pretty sure it's dried out fully.
if you didnt even repaste, that's definitely the culprit. thermal paste isn't really reusable
So, I recently got a used H100i Extreme Performance AIO and temperatures went to 100 degrees celcius under load so i thought it was broken; however, I was told this is due to the thermal paste. I have ordered Arctic MX-2 thermal paste and wanted to ask how much of a difference this would make.. I currently have some worn out old thermal paste on my cpu and im pretty sure it's dried out fully.
I just wanted to know what temperatures i would get with the thermal paste applied?
I bought the AIO cooler since I wanted to try some overclocking but i'm not sure if this would be possible.
Main RIG:
Motherboard: Z170 Pro Gaming, GPU: GTX 1070 MSI Gaming Z, CPU: i5 6600k, Memory: 16GB (8GB HyperX Fury DDR4 + 8GB Corsair Vengeance LPX DDR4), PSU: TX550M 80+ Gold Certified 550W SSD 1: SN850 500GB M.2 NVME SSD 2: Kingston A400 120GB
https://linustechtips.com/topic/1261296-thermal-paste-question/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147246
So this would impact it alot? Since I really wanna try get into overclocking.
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147249
yes, fresh paste should have a very large impact
Primary PC:
PSU tier list
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147269
How much degrees do you think the cpu would average on base clock 100% load?
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147431
I can't say because I don't know what case you're using or what airflow or fan profile, or if your room is a hot room or something
what I can say is that it won't thermal throttle anymore.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147433
I have a pretty cheap case, I think its the AVP Kolus.
My room, is pretty hot, like 23 degrees+
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147437
Yeah this is the case.
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147438
Apart from that, do you think it'll be possible to do some overclocking with the thermal paste on?
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147478
for sure, a 240mm radiator is plenty to overclock a 4 core CPU.
although I didn't notice that you said used in the original post, make sure the pump is working properly and that the tubes are hot when you apply new thermal paste and run the system. If the CPU is hot and the tubes are cold, you might have a different problem.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147491
Well the tubes are very cold, but on the software it's saying that the pump is running at around 2300+rpm
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147496
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147499
at this time the tubes would be cold because the thermal transfer from the CPU is inadequate
Primary PC:
PSU tier list
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147554
Ah, alright.
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14147590
Put on the new thermal paste and im not even getting over 40 degrees under full load!
Main RIG:
https://linustechtips.com/topic/1261296-thermal-paste-question/#findComment-14155177
