Hello guys, anyone know why this happen to my monitor? it mostly happen with black degradation but it can be noticible with other colours too
my monitor is an viewsonic xg2401, i know its not a very good monitor but im pretty sure this problem is somethig new, i noticed it like 1 week ago or something
thanks!
https://linustechtips.com/topic/1260557-black-scales-problem/
Link the wallpaper so we can check make sure its not the actual image.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1260557-black-scales-problem/#findComment-14143699
in the first image you can notice it in the black hair, in rey light's saber and the last one pretty much everywhere, anyway this also happen in some games like genshin impact and the witcher 3 at night, also in the battlenet launcher is really noticible but is kinda hard to see in the image
https://linustechtips.com/topic/1260557-black-scales-problem/#findComment-14144629
Those images do have banding present in them beyond that which is caused by 8bpc, especially the last one.
See how your system performs when displaying the below test
http://www.lagom.nl/lcd-test/img/gradient-h.png
Can also download a test image from rtings
https://www.rtings.com/images/test-materials/2016/gradient-16-bit.tif
https://linustechtips.com/topic/1260557-black-scales-problem/#findComment-14144742
it is called banding? sorry i have been using a wrong term, my english is not that good
so there is nothing wrong with my monitor? because those 2 images that you linked looks fine to me, no banding
https://linustechtips.com/topic/1260557-black-scales-problem/#findComment-14144895
If u see no banding then yes the monitor is fine in that respect. The images (wallpapers u linked) themselves are the cause, as mentioned.
Banding in games can be either caused by the fact its just the way the game was made, with what ever color depth they used,
or
Possibly an issue with the AMD driver and the way its rendering.  You'd have to check with other users of those specific games. I dont play either of those u mentioned so cant check myself.
https://linustechtips.com/topic/1260557-black-scales-problem/#findComment-14144950
