Hello, I would like to ask for help. My laptop is Lenovo G480.. It has 4gb ram installed but it got 2.88 Usable RAM. I would like to fix it, I tried 2 methods for fixing and did not work. Written below are the steps I have done for fixing it which did not work in my case.
1. Windows+ R --> msconfig --> BOot --> Advance Option --> Uncheck MAximum Memory = NOT WORKING
2. System Properties --> Advance --> Performance Settings --> Advance Virtual MEmory CHange --> choose No Paging File  = NOT WORKING
I saw a third one online but the problem is I cant find it on my BIOS
1. Memory Remap = NOT IN MY BIOS
Can anyone please help me?
https://linustechtips.com/topic/1260015-usable-ram-not-fix/
it is probably normal since it seems like your system takes 1,12gb of ram, and that is why you have 2.88gb usable
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1260015-usable-ram-not-fix/#findComment-14136506
Your System uses a certain amount of RAM. There is no fix other than get more RAM.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1260015-usable-ram-not-fix/#findComment-14136532
