so i am looking to stream some of my older game consoles on my youtube channel mainly systems like the genesis saturn 3DO PS3 etc any idea what capture device would work for me that isnt to expensive like 200$ or less
looking for a constant 60FPS+ 1080p is the native res for both my tv and my monitor if it matters also the only mic i have is the one in my C920 webcam
https://linustechtips.com/topic/1259628-need-a-good-capture-device/
One of my good friends uses an Elgato HD60S to stream his PS4 pro to Twitch through his PC and he's had great success with it. 10/10 would recommend as a budget option for the same purpose especially since it's right in your budget range.
https://www.amazon.com/Corsair-Zero-lag-passthrough-Ultra-Low-Technology/dp/B07XB6VNLJ/ref=sr_1_3?dchild=1&keywords=hd60s&qid=1603167019&sr=8-3
https://www.newegg.com/elgato-game-capture-hd60-s-usb-3-0/p/N82E16815131034
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
+1 make sure you have a USB 3.0 port, I had to help him troubleshoot why his gameplay looked like it had a horrid bitrate, turned out he was using a USB 2.0 port
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
@Chronified i have an asus CH7 with a 5700 and a 3900X so i think im good there lol
