Modem Help
Go to solution Solved by Bombastinator,
39 minutes ago, CoolName80 said:
I was looking at my modem setting and saw a option saying (modem only - modem + router) I was wondering what option is better and wanted to see if there any benefits to an option? Another question I had is if I should have the lights on my modem blinking or have them still?
My modem is a netgear D7000
Sounds like you’ve got a modem/router.  They’re different components, though most modern modems have a router in them.  If you’re not using it to route you could theoretically turn it off.  Whether it will help anything or not is another question.  That’s mostly for “i want to use a different router with more ports”
https://linustechtips.com/topic/1259579-modem-help/
-Moved to Networking-
Please don't double or triple post, and try to post in the correct subforum
https://linustechtips.com/topic/1259579-modem-help/#findComment-14132796
https://linustechtips.com/topic/1259579-modem-help/#findComment-14132816
Sorry still new to the site, didn't mean to do a double post I wanted to change the title on the topic and I don't know how to delete a post.
https://linustechtips.com/topic/1259579-modem-help/#findComment-14135123
Understood, thanks for the info.
https://linustechtips.com/topic/1259579-modem-help/#findComment-14135128
