Budget (including currency):  500 gbp
Country: UK
Games, programs or workloads that it will be used for: Games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 1 monitor, keyboard, mouse
https://linustechtips.com/topic/1259371-help-with-building-pc/
I would get a used optiplex and get a gpu.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1259371-help-with-building-pc/#findComment-14130835
No. That's fine for a $200 PC, not this budget.
Do you already have these, or do you need to fit them into your £500 budget? If you need the build to include them, here-
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1259371-help-with-building-pc/#findComment-14130867
CPU - Ryzen 5 5600X | CPU Cooler - EVGA CLC 240mm AIO  Motherboard - ASRock B550 Phantom Gaming 4 | RAM - 16GB (2x8GB) Patriot Viper Steel DDR4 3600MHz CL17 | GPU - MSI RTX 3070 Ventus 3X OC | PSU -  EVGA 600 BQ | Storage - PNY CS3030 1TB NVMe SSD | Case Cooler Master TD500 Mesh
https://linustechtips.com/topic/1259371-help-with-building-pc/#findComment-14131783
