Was inspired by various YT channels to include LTT, this is actually my first ever build and it blew me away by how it actually turned out. I learned how to build simply by watching multiple step by step guides for it and how to set up bios, etc. I have yet to name this but I think part of the concept was mainly from looking at Alienware pics sometime ago and wanting to make something that really deserves that name. I'm not much for a gamer, but I plan to utilize this for animation and evolving my art from just having an iPad alone.
https://linustechtips.com/topic/1258960-first-pc-build/
Damn man, awesome build, I love the way you angled down the gpu, maybe I could try that, how did you do it?
https://linustechtips.com/topic/1258960-first-pc-build/#findComment-14127621
Too easy, all you need is an extending riser cable and a bracket, my case came with both but you can get them pretty cheap too, the downside is being this card is as beefy as it is, it sags on the right, still screwed in, though I'm still trying to find like another little bracket or something for the extra support
https://linustechtips.com/topic/1258960-first-pc-build/#findComment-14127627
Good job man you should be proud
https://linustechtips.com/topic/1258960-first-pc-build/#findComment-14127642
17 minutes ago, Ankh tech tips said:
Yeah well then you're lucky can you list the specs
Here you go:
CoolerMaster C700M
Aorus X570 Elite Wifi
Ryzen 9 3900X
Aorus 2080 Super
4X16GB trident z royal
EK Water Cooling block, tank and pump, 420 radiator
3 CM 140 fans front, 3 corsair rgb fans top
PNY SSD 1Tb
https://linustechtips.com/topic/1258960-first-pc-build/#findComment-14127692
2 minutes ago, Verve said:
Here you go:
CoolerMaster C700M
Ryzen 9 3900X
Aorus 2080 Super
PNY SSD 1Tb
noice
https://linustechtips.com/topic/1258960-first-pc-build/#findComment-14127695
Never seen an angled bracket before.  I’ve seen vertical ones but not an angled one.  Trying to figure out how the i/o is handled.   Looking up the case and perusing pics, it seems it may just  not be and you’ve got to plug and unplug internally?
https://linustechtips.com/topic/1258960-first-pc-build/#findComment-14127713
All you need to do with it is mount it on the bracket with some screws, the cable plugs into the bottom of the card and extends to the motherboard, the downside is that it may not be the best idea when you're bridging two cards together, unless you can find a big enough bracket (or make one), also, there's a reason I went with a liquid cooled gpu setup: those fans are blowing hot air into the motherboard like that
https://linustechtips.com/topic/1258960-first-pc-build/#findComment-14127820
